enable mvr
enable mvr
Description
Enables MVR on the system.
Syntax Descripton
Default
Disabled.
Usage Guidelines
None.
The following command enables MVR on the system:
enable mvr
This command was first available in ExtremeXOS 11.4.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MVR feature, see the Switch Engine v33.1.1 Licensing Guide document.
